2022 Expedition Brake Controller
DougBriley
somewhere USA
Yes there is.
DougBriley
somewhere USA
More
DougBriley
somewhere USA
The only issue that I ran into was the dealerships in my area did not have a 2022 expedition forscan update. It’s been a long while sense I’ve checked to see if they have it yet
SuperDaveA
Reno, NV
Does forescan that people use on this forum have the needed update?
Pancho258
McALLEN, Texas
Had an 18 F150 with no factory brake controller. Bought a factory brake controller and that one pushed right into place against a connector.
Now the dealer will tell you that they have to perform a function so that the truck see’s the controller and the computer system will control it. If you’re comfortable with getting into your truck computer there is a simple way to do it yourself. I recommend doing some Google searches for UTube videos that will guide you on how to make bit changes. You’re going to need to download Forescan and pay a small amount to access the software to enable making the change. The only other device will be a cable which you can buy on Amazon for less than $30.
Ive got a 22 Timberline with the HD tow option so I don’t need to get into adding the brake controller. Something you need to know, there is likely a section of harness behind the dash where the controller connects to with a short harness section that should come with the controller or should be available ato be purchased. Again someone has probably created a UTube video.
one last thing to mention, FORScan can turn on options that are capable of running on your vehicle but have not been activated because you did not pay for that option.
chelciestokes
deridder,la.
The dash changed for the 2021 F-150.
Also, the TBC part number (Part #: JL3Z19H332AA) says it is the 2018-2023 Expedition and 2015-2020 F-150. No 2021 F-150 support. Looks like it is a different parft number.
Did you install that controller in a 2022 expedition? I’m having trouble finding a controller that is from ford.
Badan
PA
could you get this squared away yet? it has been almost 2 years now and I am wondering what you have discovered. I have a 2023 expedition XLT and of course had the same issue, before today that I find this forum and read every post line by line, the missing part of puzzle for me was the Jumper Wiring Part#:NL1Z14A411F . I looked everywhere to find such a part and I have just ordered it hopefully when it arrives , I can plug it in behind the dash and get the TBC to work. Appreciate sharing the valuable information .
I even tried to make a video on YouTube to get some help :
SuperDaveA
Reno, NV
I'm also curious if anyone has run this completely to ground (ie was able to install all the OEM brake control items and get the system to recognize everything so it works seamlessly as if it was installed at the factory). After market brake controller just isn't an option for me since this is my Wife's truck and she is very sensitive to "non-standard equipment" installed in her vehicle.
Mctaf
Alabama
The video above looks accurate - the wiring w/plug is in the back of the hole inserted vertically into a dummy receptacle. Not sure about the switch he found - if anyone else has info please post
