2fer today. Cigarette lighter loose and trim paintes.
Robert Smith
Reno, NV
Hi gang.
The cigarette lighter in my ‘08 is loose. Does anyone know how to tighten that thing up? We have to keep those electronic devises charged ya know.
Also I have the black pleather dash with silver-metallic trim on each end and other places. Does anyone know where I can get spray paint to match that? I have some good sized scratches that I think will take maoremthan touch up.
Thanks!
jim midd
Baltimore
I don't think you can tighten those. They just kind of snap into place. I have replaced all except the passenger side front one with dedicated USB sockets. It's easy and so much better
if you have the factory ashtray up front that one can be a slight pain, but it's still relatively easy . After I did it i started wondering why I even have an ashtray so I took it out and replaced it with the blank plate. I like that better
I use a socket with a built in voltmeter up front, and ones without everywhere else. If you are just plugging in USB cables, this is the way to go IMO. I left the passenger footwell one as a lighter socket just in case I ever need to plug in an old school plug
If you decide to do something like I did keep in mind that the rear cargo area lighter is on a different fuse than all the other lighters. These are all hot all the time. You can swap them out and terminate or solder the ends without pulling the fuses, but it's easier if you pull them ahead of time
Robert Smith
Robert Smith
Reno, NV
That’s a great idea Jim. I’ve seen those but I never connected the dots. If the lighter snaps in, will it snap out too? I would like to try that. And thanks for the link. Is the voltage displayed the voltage going to the adapter, or the alternator output voltage?
jim midd
Baltimore
I guess the voltage is the same either way, huh?
It actually goes down a little when you plug something in, even your phone.
on a related note: A lot of people worry about these on a constant hot outlet, as the guage is lit all the time, but it uses so little power it doesn't matter. my truck is not a daily driver and sits weeks at a time. this thing has never drained the battery
jim midd
Baltimore
Yea, lighter is easy to take out. if you are talking about the dash one you just need to pop up the plastic "tray" in the bottom of the tray in front of it, and use a 7mm socket to remove one bolt. then open your console lid, grab the area between the cup holders and console and pull it up. unplug the harness and push the lighter out. then take a razor knife and cut off the two little tabs in the hole. Pop the new outlet in, tighten the nut that came with it, then cut off the factory lighter plugs and either solder or crimp on a couple female connectors. It's really easy
Robert Smith
Robert Smith
Reno, NV
It sounds easy. I may attempt it. Thanks! I’m not sure about some of the instructions but I’m hoping they will become self evident as I work.
jim midd
Baltimore
It really is easy. the rubber mat in the picture is what you need to pull up to get to the only screw ( comes out with 7mm socket)
Bain64
What voltage does it get down to after sitting for a few days or a week with this plugged in?
jim midd
Baltimore
I have a total of 3 of these USB outlets on this truck. 1 shows voltage, the others just have a single LED. They are all always on, because the circuit is always hot. To be honest I've never really paid attention to the voltage reading after a couple weeks of it sitting, but it's always enough for it to start.
If you were really concerned you could easily wire in a toggle switch to turn off the light, and I recently saw a socket that has a switch built in haven't tried this one but looks like a decent alternative if you are willing to give up one USB and are concerned about the drain of the voltmeter always on
The only time I have battery issues is in spring, after it sits for a couple months. This year I'm going to mount a hardwired solar panel trickle charger/maintainer on this truck. I did that on my first gen and it worked great
