hyperLITEspeed
I am working towards lifting my '04 with a 3" front and 2" rear lift (leveling). I have the lift spacers and they will be easy to install on top of the coil-over struts. I jettison the air-ride years ago and the coil overs have been great.
Now that I am ready for the leveling lift, I looking run the following setup:
If you answered YES to the above three questions, then I would like to know more about your specific wheel and tire setup. I would like to know the following:
- 17" wheels with 35" tires.
- Have you lifted your ride with a 3" front, 2" rear?
- Are you running the 17" wheel?
- Are you running 35" tires?
- What are your wheel specs of your 17" wheel?
Mostly concerned with width and offset (back spacing)
- What are your tire specs of the 35" tire?
I will be running the Mickey Thompson Baja ATZ P3 LT315/70R17 35X12.50R17
- Did you have to do any body cutting to make this fit for tire clearance?
