4th Gen Expy FORScan Modifications
Breaker
Katy, Texas
Question for everyone, has any one ever had the code change on it's own after changing and writing?
With adding the seat icons in sync, and losing rear controls, wife opted to have back the rear controls. (KIDS)lol
I went in, changed it back to the as built code, wrote it, then it did it's thing, and when it came back, the seats were still there.
Went back into APIM and the code was different from what I entered.
Also, what spreadsheet is the most current?
LokiWolf
Moderator
Richmond VA
@LokiWolf - any updates to this test version I should know about? I'm about to get it set up and try it out.
Haven’t made any changes since I did the initial ones, and no issues.
The full version of 2.3.33 came out on May 8th, I would recommend that over the beta.
LokiWolf
Moderator
Richmond VA
What Year?
DenSanAZ
Arizona
I tried it today and confirmed that the values in the F150 spreadsheet work for global windows.
Global Window Open/Close
BCM 726-17-01 0101 0101 014A
BCM 726-17-02 0101 0101 014B
BCM 726-30-01 0101 xxxx xxxx
DDM 740-05-01 Dxxx xx
PDM 741-05-01 Dxxx xx
On page 101 of the manual it mentions that the moonroof may have an option to vent using the key fob. Can somebody with a Platinum or limited confirm that the vista sunroof does or does not open with the global windows?
My 2018 Panoramic Roof does not vent with the Global feature, nor is there an option for it in the menu. I would love for it to vent, AZ summer is already here and my Expy gets pretty dang hot inside!
bushpilot
Houston, Tx
The roof does not vent on our '20 / Limited when using the Remote / Global Windows (down). Having the sunshade (open or closed) has no impact.
scottdm
Western PA
Wondering if anyone has identified what’s required to have the speed limit appear on the IP consistently without needing to select the compass/navigation screen in the IP. Didn’t know if there is an IPC module setting that can be adjusted in Forscan or if it’s strictly a Sync issue. I’m running Sync 3.4 version 20021 on a 2018 Expedition if it makes a difference.
sanman28
SW MO
Anybody know the double honk code for a 2020? The F150 code doesn't seem to work
LokiWolf
Moderator
Richmond VA
There is a 2020 FORSCAN thread around here somewhere. The 2020 has COMPLETELY different coding for the BCM and a few other modules. Do not use other vehicle coding on it, even 18-19 Expedition.
Make sure you are running the newest FORSCAN, and use the BCM quick options. It is in there as a drop down choice. That should always be your go to, before actually changing code lines.
bushpilot
Houston, Tx
@sanman28 - as @LokiWolf says there is a thread (w/ my name on it)...I got rid of it....I seem to recall having to use the F150 worksheet...but honestly dont recall now.
I also enabled Bambi mode (it was a challenge but search, specifically w/ my name) youll find it.
sanman28
SW MO
Nope. Again. BCM codes for the 18-19’s DO NOT work on the 2020’s. You don’t need the actual codes, if you are running the newest FORSCAN software, it is in the easy selectable options. No need for the code!
Sent from my iPad using Tapatalk Pro
Sorry...just started playing with this last nite. I have 2.3.34beta. Where are the easy options located?
LokiWolf
Moderator
Richmond VA
Not sure that is the correct version. As long as it is equal to or later than the version posted in the 2020 thread you should be good.
There is BCM as Built, and the other BCM option. One is actual code, and one gives you drop down options. They won't all work for your vehicle, and if they don't it will tell you it can't make the change, or you can just switch it back and apply the previous setting.
It is the far safer way to do FORSCAN. Also, make sure you save a copy of your module before you start making changes, just in case.
The double honk does definitely work.
sanman28
SW MO
ok thanks. Ill look in lunch break. And yes.....things can go array fast! I changed one messing around and got serious warning lights and chimes and all kinds of error codes. Had to change back and clear all faults. About chit my pants. Truck has 400 miles on it.
LokiWolf
Moderator
Richmond VA
Yeah, I am VERY comfortable with FORSCAN, and messing with our 2020 got hairy at the beginning, hence the 2020 thread.
I worked with a FORSCAN engineer to determine differences, and gave him copies of my modules in comparison to another member on here's 19, and they very quickly figured out what was going on. Bam, we had a version of FORSCAN that worked with the 2020 Expeditions.
FORD combined modules into the BCM that were previously separate. It is the same on my 2020 Explorer.
sanman28
SW MO
Ok that worked. Thanks. Now what else can i screw with......
LokiWolf
Moderator
Richmond VA
Upon doing this......does the dash still say door adjar or open or whatever? Just no chime?
Honestly not sure. Not sure I made that change. Need to look at something else tonight. I will add it my list to check out.
