JuniorExp03EB
Ok so i hooked up a Smoke Machine to the truck. Egr has minimal leak so does the grommet on the brake booster.
I will be replacing the Intake Manifold, EGR, Idle Control Valve, and PCV Hose, Brake Booster grommet.
My BARO Reading is 81.. i was reading it had to be around 150? or is that unrelated.
I removed one O2 Sensor to see if the Cat was clogged but it still ran like shit.
idle is fine, and non running pulling the throttle body will accelerate to high rpm no problem. Shifting is good if i keep under 2k RPM
Codes are: P0174 P0171 P1151
Any word of advice? Thanks.
