5.4l Eddie Bauer 2WDA
Tyfair
Eastvalr
Hey guys, I would like know how much of each do I need. This is for 2000 Ford Expedition 5.4L 2WD.Thank you
Motor Oil: 6 Quarts
Transmission Fluid: ?
Antifreeze: ?
Brake Fluid: ?
Power Steering Fluid: ?
Yupster Dog
Moderator
Antifreeze: ?
Brake Fluid: ?
Transmission fluid:
14 quarts total to change it all. But you will only get 5 to 6 quarts on a service change. (drop the pan, change filter) To get the rest you would have to do a flush so add another 3 quarts to be sure you have enough.
Transmission must always have fluid never run engine with it dry.
Antifreeze: 12 quarts to change it all. But when you drain the radiator you only get 4 to 5 quarts out. Once again you would have to flush the system to get it all. When you flush with water make sure you use the concentrate Antifreeze not the 50/50 to fill and use a tester to make sure you get the correct mixture.
As far as the brake fluid and the power steering fluid I always buy 2 quarts but usually end up only using 1 quart or less when I flush them.
