Got the truck back already..they did as you said, no need for any parts, just did KAM reset, test drive, and retest afterwards.I hope you told them to clean the MAF and check again before replacing any parts. That bug on the MAF will certainly screw your O2 numbers.
Good question. Just drove from NJ to Alaska, stopped for full scheduled service in Minot ND on the way up. Got down to Houston, did full scheduled service on July 11. Presumable air filter was checked both times. We did drive through some intense bug clouds. So it's ironic that it choked on a bug in Texas.Also how did a Bug get past the Air Filter ???? Have them check the air intake system. Should also change the air filter.
The codes were P2195 and P2197 and then they found a bug stuck in the mass air flow sensor. My Expedition choked on a bug?
Sent from my LM-G820 using Tapatalk
Well, run a test. Remove your MAF, cover it with some masking tape, re-install and fire it up. The results would be empirical.ManUp is speaking sense. The whole story is screwy. And no O2 sensor or mass air sensor's going to lock the throttle at 300 RPM.
