jlo82585
hey y'all, I was a mechanic in the army for 3 years and I very recently started working as a diesel fleet mechanic so my A/C skills are pretty much non existent but I know enough to make me dangerous, so here's my issue.
My 2002 E.B. A/C was working but not well at all, I think on an 78 degree day it could only manage to blow 62 degree air, I popped the hood and noticed a neon green ( Freon ) leak off the condenser up front so I drew down the system ( i want to say it had 2.75-3 lbs in it ) and replaced the O-rings. I ran a vacuum test on it and it held just fine so I recharged it with what I thought was 3lbs 14 oz ( which is 61 oz if my math is correct ). when I started it after that the compressor wouldn't kick on at all. I found out the A/C machine scale was hung up and not reading correctly so I fixed it and re-zeroed the scale and drew down the system again this time taking out 4lbs 10 oz, waay more than I needed. I recharged with 3lb 14oz again but still the compressor isn't kicking on? It was before I decided to "fix" it, any ideas?
