Trainmaster
Old School Member
I find similar pressures and temperatures with my '08. It works fine, though I've had cars that were colder.
High side pressure is too high, low side to low. Have you cleaned the condenser coil in front of radiator?
After cleaning the condenser and turning on the rear ac I was able to get the evaporator temp down to 39 degrees without changing or adding anything, thank you to everyone that helpedI have found with my 08 if the rear AC is off the front AC doesn't cool as well... on a 90-91 degree day with the rear off the center front vents get down to 49 or so... with the rear on the same vents get down to 39 degrees... on my 01 and 06 the where similar(3-5 degrees difference)... but on the 08 it was a bigger(10 degrees) difference between on and off.
