A warning…
Mikezr
Canada
I went with the melling 340hv and all factory parts going on 2 years now and the truck is mint. The oil pump was probably the single biggest issue with the 3v timing system. Few things i would change on them but overall when taken care of those motors can last a long time
Carl Keef Jr
Cedar Park, TX
WEDGE
Kimberley BC Canada
well the 340HV pump has the same oil pressure according to FordTechMakuloco. what brand for the cast iron tensioners did you get? I had found some from Melling on amazon, also can you confirm what someone said on youtube as far as making sure to NOT use the metal backplate on the tensioners?
I used all OEM Ford parts, with the exception of the oil pump. I work for Ford so that helps
My theory on this is that high rpms caused the failure of the new tensioners. Just the way they blew out seems like it happened under high stress like a wide open throttle situation. I’d highly recommend cast iron ones, I’m going to slip a pair of new ones in and chains/ sell the truck for a few bucks.
Mikezr
Canada
I run a melling hv340 going on two years now and she's still good to go. That said I've heard my share of horror stories about the factory parts failing.
Brons2
Austin, TX
I bought the metal ones for my upcoming timing job. I need to get at it before summer hits, it's hot here in Texas.
jcason94
