ABS Light
WPG2013
Whitefish,Montana
Just finished a 3000 mile 'round trip from NW Montana to KC, pulling my single axle utility trailer. Installed Powerstop Extremes on all four corners prior to leaving. About 100 miles into the trip I started getting an intermittent ABS light with occasional peddle feel like trying to stop on ice.
Light would reset after shutting down and restarting.
Bedrck47
Elizebethtown, PA
Have the code read and post it Then we can give you a better idea as to which sensor is bad or if its the ABS module.
Bedrck47
Elizebethtown, PA
Copied from the 99 service manual
Attached is a list of the ABS codes that you may get. When you get the code post it and we can give you some better information
Anti-Lock Brake Control Module Diagnostic Trouble Code (DTC) Index DTCs Description Action
B1342 Anti-Lock Brake Control Module Failure INSTALL a new anti-lock brake control module. REFER to Module—Anti-Lock Brake Control . TEST the system for normal operation.
C1095/C1096 Pump Motor Go To Pinpoint Test L .
C1113/C1115 Internal Power Relay Go To Pinpoint Test M .
C1145 Right Front Wheel Speed Sensor (Electrical/Static) Go To Pinpoint Test G .
C1148/C1234 Right Front Wheel Speed Sensor (Dynamic) Go To Pinpoint Test H .
C1155 Left Front Wheel Speed Sensor (Electrical/Static) Go To Pinpoint Test E .
C1158/C1233 Left Front Wheel Speed Sensor (Dynamic) Go To Pinpoint Test F .
C1169 Excessive Dump Time Go To Pinpoint Test O .
C1184 ABS System Timeout Go To Pinpoint Test N .
C1185 Open Internal Power Relay Go To Pinpoint Test M .
C1194/C1196 Dump Valve, Front Left Go To Pinpoint Test D .
C1198/C1200 Isolation Valve, Front Left Go To Pinpoint Test D .
C1202/C1204 Dump Valve, Rear Go To Pinpoint Test D .
C1206/C1208 Isolation Valve, Rear Go To Pinpoint Test D .
C1210/C1212 Dump Valve, Front Right Go To Pinpoint Test D .
C1214/C1216 Isolation Valve, Front Right Go To Pinpoint Test D .
C1220 Yellow Anti-Lock Brake System (ABS) Warning Indicator Failure Go To Pinpoint Test C .
C1222 Wheel Speed Error (Dynamic) Go To Pinpoint Test N .
C1229/C1237 Rear Wheel Speed Sensor (Dynamic) Go To Pinpoint Test J .
C1230 Rear Wheel Speed Sensor (Electrical/Static) Go To Pinpoint Test I .
C1226 Brake Warning Lamp On REFER to Section 413-01 .
Atlanta
OK. so I had something similar a while back. The main thing that caught my eye is when you state you are pulling a trailer. I had the same issue with the ABS coming on. Months of investigating and it ended up being the gear and pinion in the rear diff was completely broken (only after a heavy, long haul tow). Drove around for quite some time with it broken and had no idea. Pulled off the rear diff and the gear was completely broken.
WPG2013
WPG2013
Whitefish,Montana
Geez! Really didn't need to hear that! Might take a peek at that this weekend.
