Abs module
Atlanta
anyone try disconnecting and bypassing the abs module all together. I am having a problem with the abs light going on and off, while the brakes keep pulsating. Doesn't do it all the time, but when the abs light comes on (and the abs module quits working) the braking is much, much better.
Iif anyone has any ideas it would be much appreciated!!!
B
bedrck46
see if you can get a readout on the abs codes most likely a bad sensor
stamp11127
Temple, Georgia
The abs module has detected a speed difference between the wheels. That is usually one of the wheel sensors has failed or has a bunch of crap on the end. If it is anything like the buses at work, when you change one you'll end up changing all of them.
GaExpedition
us
I unplugged mine due to the pump constantly running. Only downfall I had from disconnecting it was I lost cruise control. I hope to get to a salvage yard soon and swap it out.
