You can either chase down the cause and repair the air suspension, or just convert to standard struts/springs and never worry about it again. There's ups and downs to both options.
Hi, Check the o-ring on the AC pump dryer. the dryer connects to main compressor with a simple 1/4 turn and hold down screw. After that went through 2 compressors ( 2 years apart) and switched over to strut/spring rear suspension. Cheap fix $300.00 bucks not as firm a ride but I never have to worry about a suspension issue. I actually like the truck more as I never trusted the air ride. Also check your ride levelers as if one goes the compressor runs till it overheats and dies, a really bad design.
Comparing the ride on the 05 to the ride on the 17. The air suspension on the 05 rode firmer than the spring shock combo on the 17. Not that the 17 has a bad ride, just different.I thought the air suspension had a softer ride than strut/springs. Is that correct? Thanks
Arnott is the only one that offers a module to keep the check suspension light off so I gotta ask, does it work?My 2007 Expediton had the Air compressor go bad, and I replaced it with one from Suncore industries, that one seemed to die recently, and I suspected that it was working too much or too hard due to a leak, in any case the rear end sagged down and I was down to the bump stops.
I purchased a coil spring kit from Arnott (just the rears) and recently installed it myself .... not too bad a job if you can do brakes .... I did it in my own garage no lift just jack and stands...
In any case my early verdict is I am happy with the rear height being back to stock and the ride of the vehicle is very good again. I won't miss the air suspension troubleshooting. It was nice while it worked, but I like the setup now. Good luck!
I installed the Arnott shocks on my 2010 Expy. The module definitely works.Arnott is the only one that offers a module to keep the check suspension light off so I gotta ask, does it work?
