Another ac question
leogla
Orlando, Fl
Hi
I got a limited 2006 5.4. Suv is great. The ac work half
Way. Got the ac at max and air go throw front and then shut throw
Windshield. I check the vacuum lines replace one close to the battery
and back the console there is electric box that came all vacuum
lines, but still the same problem. The other day I found if I go
up with the degres bottom, then air flow go the front, but here
in orlando is very hot, I want the ac on 60• My question is
possible that electronic ac control is bad or I still need to
find a vacum problem?
Thanks for you time.
Note: sorry with my English very slow
stamp11127
Temple, Georgia
Do a Google search on how to run the diagnostics on the electronic temp control for your year. That will let you know if there are any codes present for that system.
