Auto up/down reinitialize
Tocapet
Tocapet
Texas/Colorado
sorry hopefully some others may chime in with better advice and results
This is one of the procedures I used.. I found it here on the forum. (Thanks to RI-Matt!) It's similar to yours, but written for a 2008. Maybe someone has the 2009 procedure??
  • 5654d1356732603-window-auto-up-window-motor-initialization-general-procedures.pdf
Bedrck47
Elizebethtown, PA
When you finally find the correct procedure or the solution to your problem kindly post a update Thanks
Bedrck47
Elizebethtown, PA
Being you have found different procedures for this problem just shows why it is very important that the year, model and other information is needed when asking for help
Also it helps when people update their signature and provide information about their expy/nav
Tocapet
Tocapet
Texas/Colorado
Well, nothing seems to work. I must be missing something. But for now, I guess I'm resigned to the fate of holding down the button. No more auto-up/down. Or else go see the dealer and spend big bucks :(
Bedrck47
Elizebethtown, PA
just looked this up in the 07 manual might be worth while checking
The one-touch down feature is inoperative — Expedition
Master window control switch
INSTALL a new master window control switch. REFER to Window Control Switch in this section.
Tocapet
Tocapet
Texas/Colorado
Thought of that, but it was working fine before the regulator messed up. Even after it messed up it was "trying". I metered the fuses and they all get 12V on both sides. I hate to go buy a new switch and have it still not work :( Please send me the info when you get it.
Bedrck47
Elizebethtown, PA
the following was copied from the 2009 Ford workshop manual
Window Motor Initialization
NOTE: Initialization is required to learn both the full UP and full DOWN positions and the profile of the glass as it travels through the glass channel. Once initialized, obstacle detection is enabled. This procedure is only required for Navigator (LF and RF) or Expedition (LF only) window motors.
NOTE: The window motor must be initialized whenever: the motor is removed from window regulator drum housing, a new motor is installed, a new window regulator is installed, new window glass is installed, glass top run removal or installation is carried out or when carrying out any operation in which grease or lubricants are applied to the window system. All window components (window glass, window regulator, window motor and glass top run) must be installed and tightened to specification before carrying out this procedure. Refer to the De-Initialization Procedure prior to performing the window motor initialization (unless a new motor is being installed).
NOTE: A new (or de-initialized) LF/RF (Navigator) or LF (Expedition) window motor will not operate in one-touch up mode until initialized. If a new LF/RF window motor has been installed, proceed to the Window Motor Initialization procedure in this section.
NOTE: Excessive bounce-back (window reverses direction with no obstructions present) may indicate that a de-initialization procedure may need to be performed.
Start with the ignition key in the RUN position and open one front door.
NOTE: Steps 2 and 3 must be performed within 8 seconds.
Turn the ignition key from OFF to RUN 5 times.
Press the window control switch to the one-touch DOWN position (second detent) and release.
WARNING: Keep objects and body parts clear of the glass panel when carrying out the initialization procedure. During the initialization procedure, the glass panel closes with high force and cannot detect objects in its path. Failure to follow this instruction may result in serious personal injury.
Start with the ignition key in the OFF position and with the LF/RF door open.
Turn the ignition key to the ON position.
Activate and hold the window control switch in the one-touch DOWN position (second detent) until the window glass stalls for 2 seconds at the bottom of its travel and release the switch.
NOTE: After performing this step, wait a minimum of 3 seconds before operating the window control switch or ignition switch.
Activate and hold the window control switch (with no interruptions) in the one-touch UP position (second detent) until the window glass stalls for 2 seconds into the glass top run and release the switch.
Verify correct operation of the window by carrying out the one-touch up and one-touch down features. If the window does not operate correctly, carefully repeat this procedure.
Tocapet
Tocapet
Texas/Colorado
Thank you for that. It looks like it's the same as the 2008 instructions. I'm going to try it. I also ordered a replacement switch according to your other message. Wish me luck!!!
