back to the issue at hand...
jlo82585
cedar rapids Iowa
hey guys, alright after all the other problems I have had to fix I am now back at the original problem. So we here in Iowa are slowly coming out of winter, last week we had a day where somehow we actually hit 80 degrees, just like last summer my truck as a large power loss through the power band and you can actually feel the truck surging at low rpms until it gets to 2.5-3 where either you have to give it much more gas to go faster or it just falls flat on its face. there is no CEL on for this issue. when the ambient temp is cold the truck doesn't seem to have this issue but as soon as it gets around 50 degrees it start bogging down. so far since I bought the truck last year here is what I have done: gotts mod, cat-back 3in exh. w/ muffler delete, replaced fuel pump, replaced fuel and air filters. I have not yet replaced the sparkplugs, I bought the truck with 147k miles on it and it has about 153k on it now. I would like to get this fixed before june as I have to make a drive to Florida and its going to be hot there. I just wanted your guys opinion before I take it in to have it diagnosed. thanks guys!
Mediamonkey11
Enumclaw, WA
No idea why it'd be temperature related but with that mileage I'd be sure to have replaced the plugs anyhow... That'd also give you a good look into the condition of the coils (cosmetically speaking at least), replace boots, make sure to do resistance tests on the coils while out, and go from there!
JUST4FUN
Admin
Moderator Administrator
Il
Could this be a circulation problem with the water pump. the fins on the water pump gets thin and flex . when this occurs water is not pumped correctly.
CaperCanadian
Alberta, Canada
What about the maf or temperature sensor in the air intake, would make a difference there with temperature change.
J
jlo82585
cedar rapids Iowa
yeah I do have a scan tool so I may check out the temp sensors, I have the plugs for it I am just dreading replacing them, I pulled out plug 1? ( Right front ) and it looked pretty new, still had dielectric grease in the boot. I have heard of people only changing the front 4 though so I suppose I should.. I don't think it has to do with the water pump as the water temp stays fine, it just seems the higher the ambient or outside air temp the boggier the engine is. So for the temp sensor, is it just air intake temp? also I want to be able to read the fuel trims but I simply have no idea how to translate fuel trim or what it should even be so any info on this would help. thanks guys.
sitruc_btb
Chandler, AZ
Both fuel trims should be around 1.00. 1 is perfect stoichiometric ratio. Less than 1, for example, 0.95, indicates a rich condition. What the number actually means is injector duration is being decreased. A number above 1, indicates a lean condtion. Injector duration is being increased. It's a little confusing, and I even have to sit and think about it too. Short term fuel trim will fluctuate, and this is normal. Long term fuel trim should stay around 1.00. It doesn't move around, unless there's a fuel issue, in which case long term will adjust for a given condition.
1.00 - perfect air/fuel ratio.
Less than 1.00. Rich air fuel ratio.
More than 1.00. Lean air fuel ratio.
These numbers indicate a result of fuel correction. If short term says 0.92, this means at one point the vehicle was running rich, therefore, the ecu decreased injector duration to correct the rich mixture. If short term was around 1.05, this indicates a lean mixture. St one point the vehicle was running lean, so the ecu increased injector duration to correct the lean condition.
Short term fuel trim will fluctuate constantly. Long term shouldn't fluctuate. If you have a fuel delivery issue, say, an injector is hanging open, you'll be running rich. The long term fuel trim, over time, will adjust for this issue and try to keep short term fuel trim at around 1.00.
J
jlo82585
cedar rapids Iowa
thanks for the info, so armed with that knowlage I hooked up my scan tool and took the truck for a drive both short term and long term fuel trims were all over the place under throttle which I assume is normal. after getting the truck warmed up I decided to take down the info and let you guys have a look to see if the readout seems normal, I omitted the O2 sensors as they fluctuated too much to obtain a good baseline reading but here is the rest:
outside air temp (for reference) 44F
engine temp- 190F
engine speed- 700 RPM
LT FTRM1 ( im assuming long term fuel trim bank 1)
1.5%
LT FTRM2 ( same but bank 2)
3.1%
IGN ADV ( ignition advance I assume, and these readings were all over the place but the low number is the lowest reading I saw with the high number being the highest).
14.0-20.0 Degrees
IAT - 54F
MAF in lb/min - 0.660
ABSLT TPS (again I am assuming this is the absolute throttle position)
18.8%
anything off on these readings?
J
jlo82585
cedar rapids Iowa
okay so I am still having the low power issue after changing the plugs, although new plugs did make a difference. still at about 1/2 pedal on an on-ramp the truck will pull really nice till about 1500-2000 RPM then the pull gets really slow and you can hear the engine speed surging and slowly picking up RPMS until about 3000-3500 RPM then all the power comes back and it pull hard to 4000 and upshifts. Fueltrims seem okay but I would like to get a pressure gauge on it to verify. along with the low power issue I am also getting pretty awful MPG for a 5.4. the trip computer says im getting 12mpg in town but after fueling and doing the calculations im actually getting about 11.5mpg, and im not driving her hard at all. someone a long time ago suggested this could be an EGR problem? but without a CEL its hard to say. so far I have replaced:
plugs
air filter
fuel filter
fuel pump
cleaned throttle body with carb cleaner
any suggestions on what could be causing this?
sitruc_btb
Chandler, AZ
Sorry it took a while for a reply. The primary O2 sensors will fluctuate, because they are reading the changes in exhaust gas/oxygen, fuel content. Secondary, or after cat sensors, should stay somewhat smooth. The secondary sensors monitor catalyst operation. I don't know what is considered normal for the Ford, perhaps a service manual will show what is.
sitruc_btb
Chandler, AZ
You could also adjust the valve clearance, if it hasn't been done. Maybe do a cylinder leakdown test just to check the condition of the engine. Make sure it's healthy.
tedennis
NW Ohio
OK... Upstream o2 sensors are the ones that impact fuel. They will fluctuate from about .100 to .900 volts or 100 to 900 millivolts. Depends on scanner being used. 500 is the middle. It should not stay there though. It should swing from 100 to 900 and back constantly. That is normal operation. If it is staying over 500 it is running rich. Because of this, the fuel trims will go negative. This means the computer is reducing the injector on time to cut fuel.
If the o2 sensor is reading less then 500 more often then it is running lean. The fuel trims will go positive which means computer is adding fuel by increasing injector on time.
Perfect fuel trims are 0. The goal of the short-term is to keep the long term at 0. The short term will change constantly. The long term more slowly. The short term fuel trim will increase and decrease to try to get the long term to 0. The "total fuel trim" is the short term and long term added together.
I will add more later. Got to run.
tedennis
NW Ohio
A little more. Temperature sensors can play a large part of driveability issues. If the sensor is reading hotter or colder than actual ambient temp, the computer will change the amount of fuel sent to engine. Colder air is denser air, more air molecules in same volume. So the computer will send more fuel to compensate for denser air. Same for barometric pressure. The higher the elevation, the less dense the air. If the computer does not cut back on fuel it will flood it out and it will either run very bad or not at all.
The mass air flow sensor measures the amount of incoming air to help determine amount of fuel injector on time. If it is higher or lower than actual, fuel will reflect it and cause it to run too rich or too lean. Both will cause a lack of power.
The egr opens up at cruising speeds only. It allows exhaust gases to enter cylinder which cannot contribute to combustion and just take up space. In doing so, it reduces the cylinder temperature which reduces the oxides of nitrogen produced by combustion. This will be referred to as NOX emissions. It is one of 4 monitored in states that require annual inspections.
If the valve sticks closed, you will not feel it. You should get a CEL and a code but no other ill effects. However, if it sticks open, it will reduce power, run like crap and if bad enough, stall at an idle.
Vacuum leak can cause similar issue but would be obvious. Fuel trims would be way positive at idle. Normal range is +/- 7. More than that and i get suspicious.
Personally, the way you describe it, i think you may have a mass air flow issue. But hard to say without having a scanner hooked up and chdcking. The only way to find it other than throwing parts at it is to take it to a shop that has a good driveability tech. I say good because the bad ones just throw parts at it too and charge you for them. I good tech will be able to figure it out in an hour or two with a scanner. most shops around here charge $70-90 per hour and guarantee their work.
My recommendation as a guy that does this for a living is find a good shop and let them look at it. You have already spent more than the diagnostic would have chasing it.
Good luck and please post when you get it fixed.
sitruc_btb
Chandler, AZ
The dealer is always an option. They have scan tools specifically for Ford systems, which aids in diagnosis.
J
jlo82585
cedar rapids Iowa
yeah I printed off the no CEL power loss/ surge troubleshooting guide from fords tech. website. I wont really be able to use it due to needing special diagnostic software to read ford PIDs and my $300 mac tools scanner wont do it.... essentially it want me to test the following
EGR valve
DPFE sensor
injectors
plugs
fuel filter
fuel pump
COP's
IAT sensor
MAF sensor
since fuel filter, pump and plugs have been replaced I can cross those off. I tested the IAT sensor with my scanner and its what I would call close enough ( =/- 5F ) so thats okay, COP's in my mind should create a hard miss or CEL if they were bad, so im left with MAF, EGR, injectors, and DPFE sensor. I am going to record data from the drive home from work tomorrow and see if I can find an over or under fueling situation going on. anyone know how to test a MAF sensor? They are $70-90 and I don't want to throw that kind of money at it.
tedennis
NW Ohio
Hard to test a Maf without a scanner. One way is to have truck sitting warmed up at idle and tap on it. If the engine stutters at all, is a sign it is bad.
Also, i know you dont have this symptom, but have had cars come in that would crank, no start. Unplug the maf and would fire right up. Doesnt help you much though.
A general rule of thumb i was always taught was at a warm idle, the grams per second should be close to the displacement in cc's. So a 5.4 l equals 5400 cc's of displacement. So grams per second should be close to 5400. Ive always seen that actual was a little lower than cc's. Hope this helps some.
And i have also seen brand new fuel pumps be weak. Will supply enogh fuel at idle and low rpms but lack at higher rpm. Can cause lean condition. You can check by dead heading the pump. You need a minimum of 70 psi fuel pressure. May be able to find example of test on youtube.
J
jlo82585
cedar rapids Iowa
nice I will have to try the dead head test. I am certain that there is an issue with the fuel pump as since I replaced it I have an issue with the engine cutting out on left hand turns when the tank is 1/2 full or less. also with regards to exhaust back pressure, one ore more of the cats would have to collapse in order for that to happen as I removed the muffler and resonator last summer. I am also running 3" pipe from the cats back so I dont think that could be an issue
J
jlo82585
cedar rapids Iowa
okay so I finally got my buddies code reader and recorded a short 5 mile trip and actually, I didnt see any problems, the fuel trims were where I would expect them to be all +/- 7%. o2's all looked good for the most part but they were changing too quickly for me to gather a really good reading. the power loss is still there but like I said, after the plugs its not nearly as bad as it used to be. and after the plugs the fuel mileage is around 11-12 in town and 13-15 on the highway so perhaps the plugs were the main issue. 2-3 of the 8 plugs were pretty much gone where as the others looked pretty good so im thinking COP's may be in order soon. now I just have to diagnose the issue with engine cutout on left hand turns... still looking for any information on this issue...
lunchboxlust
carthage ny
I ran my tank almost empty one time and after that the rig ran like crap some times. wouldn't always throw a code. IF I remember right it got worse on hills and fast turning. It ended up being the fuel filter. I had just put one on it not to long before that tho so I dicked around and changed all sorts of stuff first. When I change the filter again I cut it apart and it looked like it was completely full of coffee grounds.
