blue oval guy
Ok this subject has been discussed 100 times. Slow speed (parking lot speed) turning gives be a distinctive grinding or binding at the front hub ends. even very slight turning angles or anything other than dead straight give the same results. I have new front hubs but havent replaced the IWE's yet. My question - can a problem with the front diff give off the same type of grumbling? Wanted to ask before I spend hundreds on new IWE's. Also is it okay to use off brand IWE's instead of Motorcraft? i usually use only Motorcraft for everything. THANKS GUYS...
