Can you eliminate yellow shading on back-up camera?
haviland
MA
My 2011 Expy's back-up camera had a clear view. My 2017 Expy back up camera has a yellowish tint when I get close to the ball when backing up.
I need to put on my cheater glasses to see the ball to begin with, and the yellowish tint makes it even harder.
Am I missing something? Can I get the camera to show a clear view?
thanks,
Peter
LokiWolf
Super Moderator
Super Moderator
Richmond VA
thanks,
Peter
Mine is clear. Is the camera clean?
H
haviland
MA
Yes, the lens is clean. The yellow tint is a specific rectangular (or maybe square- not sure) shape. There may even be another color pattern mixed in.
It is encouraging to hear yours is clear, maybe mine can be reset somehow. What year is yours?
99WhiteC5Coupe
Do you mean the warning “blocks” that go from green, to yellow, to red as you get closer to an obstacle?
I have a 2015 Ford Expedition Limited 4x4 - and that system works in conjunction with the audible warning system.
My system is very clear and useful. However, I think you can turn off the colored warning blocks in the DIC settings menu.
My system has a “zoom” feature for the camera, which is detailed in the vehicle owner’s manual.
H
haviland
MA
It sounds like I am seeing the warning "blocks" you describe. I would like to turn them off. What do you mean by the "DIC" settings menu?
I love the idea of a zoom feature. I will check out the owner's manual to learn more.
Thanks
99WhiteC5Coupe
Thanks
The various menus in the driver information center (screen on the left side of the display dash on my Limited), can be accessed via the left-side steering wheel pad control knobs. There are various menus - and sub-menus.
You didn’t state which trim model you have - I think the lower trim XLT model may have a different DIC dash screen, and I’m not sure how to access it because I have the Limited model.
It should be detailed in your vehicle owner’s manual.
Good luck - let us know what you determine.
H
haviland
MA
I have the Limited. I'll check out the manual in the am and report back.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Thanks
That makes WAY more sense now.
These are the setting you are looking for and they are on Sync3.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
I am running 3.4, so it might look a little different...but same idea.
mossback
2017 Limited EL
WA state
Loki, is that official beta testing or did you just hot rod the system with 3.4?
