capacitor
kickapebble
Oregon
When I bought my truck, it appeared to be stock. When I went to wilre in a amp I realized that the speakers were already wired to an aftermarket amp hidden under the storage box on the driver side rear cargo area. I wired the amp for the sub by running an additional power. While making some changes, I pulled the fuse for both amps and removed the wires from them. One time, the power wire for the old amp sparked when it hit a ground, after I pulled the fuse. I took my meter and checked and after pulling the fuse, I still have 12VDC, after 10 or so seconds, it slowely bleeds down to zero. Dose this mean there is a capacitor somewhere? I pulled the wire from the amp before checking it, so i know it wasn't from leftover power in the amp.
panda24619
San Diego
yeah ive sparked b4 and nvr went down to 0. theres probably a capacitor that drained the power. thats why i dont like them. theyre too complicated. itll be close to the amp. probably no more then 3 feet away from it.
WHOISMOOTOO
Dallas, TX
honestly the cap can be anywhere from under the hood to hidden under the truck if the amp was that hidden
corlon
midwest
theres probably not a cap in the vehicle. its the caps inside the amp storing that little bit on current.
