walnuts4x4
well I bought the "Firestik ss-204A" universal door jamb mount and a 3ft tuneable Firestik antenna. The mount simply attaches to the door jamb with 4 self taping screws... I had to use one bigger screw due to the body lines were I mounted mine... the coax cable I simply removed the driver's side taillight and ran the wire behind it and straight down (once I removed light I reached down and pulled out the styrafoam (SP?) and ran the wire under the truck... then I routed wire along frame using zip ties to hold it in place... I then pulled back the carpet on the driver's side and pushed out a plug which was the perfect size to pull coax through... I cut a V notch in gromet and put gromet back best that I could and then used duct tape to seal the hole... then the coax was routed behind console to CB which got mounted to side of console... 2 star bit screws hold top of console on and once removed could easily route all wires and bolt CB in place...
