CCD Replacement Costs? (Continuously Controlled Damping)
07navi
Mt.Shasta California
An E rated tire would just be a band-aid and more money spent. That system is for 22" tires and computer controlled. Any changes would probably mess it up. That 4k mentioned earlier probably includes a computer. Most people just take them out when the time comes and put regular shocks in. Nice system it it works well and you can afford it. The computer for it changes the shock stiffness hundreds of times per second as you ride over pot holes etc. Very sophisticated.
LokiWolf
Moderator
Richmond VA
Hi all...
I just put 18” on my 2016 EL with CCD.
I have to say the ride is 100% miserable. It feels very squishy and like a boat rocking aimlessly in the sea...to the point it feels like safety issue not to mention I made myself carsick.
I’ve tried normal, comfort and sport modes on ccd.
I am not sure if this is a tire issue or what but so far it’s not good.
Tires are inflated to 38, which is what is on the sticker inside the driver door.
Any thoughts/ suggestions?? The tires are brand new all terrains from a well know manufacturer. Not a generic brand.
What is irritating to me is the retailer I purchased from has no info on the impact of CCD and different sized wheels.
Tell us the brand, size, and model of tire. You gave us very little actual data. We need details.
That being said, the 38PSI on the door is based off the OEM tire. If you have CCD, that was a 22. You put an 18 on, adding 2 more inches of side wall of squishy rubber assuming the same total rolling diameter vs the OEM setup. You most likely need to add air.
You traded wheel for tire...therefore softer ride(everything else being equal).
Give us more details on the tire...and we will start from there.
stil
Ohio
Got it. Interesting because I called 3 different Ford dealers and spoke with a service Advisor to find out if it would be problematic and they said it would not. Then again, not sure how they would know one way or another tbh.
If I swap out to regular shocks/ struts...will my Expedition throw a code? Can the system be shut off by a ford dealer after I swap out shocks/ struts?
stil
Ohio
275 65 18
Pirelli Scorpion AT Plus
I bumped the pressure up to 40 PSI today. Marginal improvement.
I fully recognize that adding more sidewall will make the ride different but I've driven an Expedition EL with 18" wheels without CCD and the ride is vastly different...granted, different tires.
LokiWolf
Moderator
Richmond VA
275 65 18
You replaced XL(Extra Load) tire with a SL(Standard Load) tire. Your OEM 22 Tire had a max pressure of 50PSI, and the SL Tire Max PSI is 44. You added a taller sidewall, with a skinnier tire, and a smaller contact patch.
Others have made the switch to 20 & 18 Inch tires with CCD, but my guess is their tire choice was better.
I think your issues are completely tire related.
stil
Ohio
Isn't "extra load" sort of misleading? The max load rating on the Pirelli's is higher than the outgoing tire...
LokiWolf
Moderator
Richmond VA
Somewhat, but the side wall is stiffer.
Bottom line, the tire is your issue, not the CCD. That is my opinion, based off experience and knowing many have made the change with CCD to 20’s and 18’s and not had the issues/complaints you have had. I would expect the ride to get better/softer but not as bad as you described.
stil
Ohio
Ok...makes sense. Thanks for your input.
guzzon
Santa Barbara, CA
Hi all...
I came across this thread after I put 18" wheels on my 2015 Limited with CCD, and wanted to chime in. I chose 275/65r18 Vredestein Pinza AT and put them on Fuel Shok wheels with +20 offset (+44 is stock). I didn't experience any major difference in ride quality. It's a little softer, which is expected, and nice, but not overly squishy and handling is still good.
Previously with the dub deuce wheels I would keep it on "normal", but "sport" feels a bit better with these tires. The struts are original and have ~72k on them, and several are leaking pretty badly, so I need to replace them and will probably go with the non-CCD struts to save some $$ and because I don't think CCD is really needed with 18" wheels. If I remember, I will update once I do that.
Thanks for the discussion - this was useful for deciding what to do on the struts.PXL_20211104_004218032.jpg
guzzon
Santa Barbara, CA
Update after replacing the struts with non-CCD: ride quality is not that different with the 18" wheels with and without CCD. CCD is definitely smoother but not by a lot with these wheels. I think where I notice it the most is the "bounce" from the back end that you'll get when you go over a bump, usually at highway speed, that has just the right timing to get it to bounce up and down. I think that's what the CCD was really good at sensing and dampening out. It feels much more like a truck in that respect now. I haven't towed a big trailer in a few years, and wonder how different that will be without CCD, if we ever get one again...
All in all I'm happy with the trade-off in $$ saved now and in the future if struts need to be replaced, and it's a capable backcountry road vehicle now with these wheels. Spent some time in the hills outside of mammoth lakes, CA last week and had a blast.
Whitebison
Asheville
How did you bypass the sensors or turn the dash light off? (Or did you?)
browncow
