Hi all...
I just put 18” on my 2016 EL with CCD.
I have to say the ride is 100% miserable. It feels very squishy and like a boat rocking aimlessly in the sea...to the point it feels like safety issue not to mention I made myself carsick.
I’ve tried normal, comfort and sport modes on ccd.
I am not sure if this is a tire issue or what but so far it’s not good.
Tires are inflated to 38, which is what is on the sticker inside the driver door.
Any thoughts/ suggestions?? The tires are brand new all terrains from a well know manufacturer. Not a generic brand.
What is irritating to me is the retailer I purchased from has no info on the impact of CCD and different sized wheels.
Tell us the brand, size, and model of tire. You gave us very little actual data. We need details.
That being said, the 38PSI on the door is based off the OEM tire. If you have CCD, that was a 22. You put an 18 on, adding 2 more inches of side wall of squishy rubber assuming the same total rolling diameter vs the OEM setup. You most likely need to add air.
You traded wheel for tire...therefore softer ride(everything else being equal).
Give us more details on the tire...and we will start from there.
