battmanf16
2002 Expedition, XLT, 4x4, 5.4L, 115,000 miles
Chasing a vibration for the last year/7,000 miles:
Description of the Vibration:
- The vibration is a low grade rumble felt predominantly in the seat, and to a lesser extent in the steering wheel.
-- The steering wheel does not shimmy like an unbalanced wheel/tire would cause.
- It is barely audible as a low ruble/hum, but no grinding/clunking/squealing sounds are evident.
- Most significantly, the vibration is intermittent. Some days, the truck drives smooth with no unusual vibrations at all. Some days, comes and goes during the same drive.
- It seems to be less common when the outside air temperature is cold - sub 40's. But this isn't always true.
- Vibration occurs most notably between 45-65mph but does continue at higher speeds - I just don't find myself much above 55mph during my 10 mile commute to base. <45mph, it's smooth or so minor as to seem absent.
- When I let off the gas on a steep enough downhill to maintain speed, sometimes the rumble intensity (not rate/frequency) actually seems to increase slightly.
-- The rate/frequency increases with increase in speed and decreases with a decrease in speed until dropping off entirely at 40-45mph.
- If I put the transmission in neutral when the rumble/vibration is occurring, the rumble/vibration continues with the same intensity and frequency even with engine now at idle RPM - so it doesn't seem like an engine issue. Of course, as the truck slows while in neutral, the vibration slows with speed.
- The front rotors and pads are new and not warped; there is no evidence of pulsing brakes. Brake application is smooth and quiet.
- The vibration might subside slightly in turns, but I'm not taking big turns at 45+mph, so it's hard to be sure. This might just be wishful thinking too.
(Failed) Attempts to fix the Vibration:
- Downloaded the computer - no codes
- New Tires <3000 miles ago. There is no cupping, feathering, or other unusual wear = no change to vibration
- Tires have been dynamically balanced & rotated twice in last 500 miles to attempt to isolate the vibration = no change to vibration
- Aligned the front end = no change to vibration
- Replaced a failed coil pack = no change to vibration
- Changed plugs <1000 miles ago = no change to vibration
- Transmission rebuilt <300 miles ago (Torque Converter failed - metal shavings in transmission) = no change to vibration
- There does not appear to be any play in the hubs, though I have not yet removed the wheels to check = I have only rocked the wheels while parked.
- Pulling on the suspension components does not reveal any play out of the ordinary.
- I have not checked universal joints yet.
Love my Expedition! It is still beautiful inside and out and look forward to many more years together. I'm open to any and all thoughts. You guys rock!
Thanks and blessings from an active duty Air Force dude,
Bob
Bob
