Fordgirl01
Thanks again for the wealth of info all of you share.
TobyU-I always love your thinking out loud posts! My brain works the same way so I get a lot out of your advice. I don’t know if it’s an intake or exhaust valve-how do you tell. If it’s from location, it is a valve on the lower (towards the drivers side fender) side. When I did the compression test (seems like ages ago), the needle did not even move-on either wet or dry test on this cylinder. Dual or single springs-I only see one per valve (obviously 4 per cylinder on this).
rjdelp-I really don’t think this vehicle was poorly maintained. I do have a few records for it and it appears it was pretty well taken care of. I don’t believe it burned oil, but of course I don’t know for sure. I will try to find some info on the leaky exhaust valves for this motor-thank you for the suggestion.
So I will plan on the air test and report how it goes and we’ll go from there!!
