Confused about 4WD and eSLD
ExpyG
Boston
Hi all,
I am coming from the Honda/Acura background. Last summer I rented an Expedition MAX for a road trip and loved it so much that I decided to buy one. So after waiting a few months, I am finally in the market for a new Expedition MAX, my first Ford vehicle :)
I am in the Northeast. All the Expys sold around here have four wheel drive, and I would not buy one without it even if they were available, because of all he snow and ice we get.
I am confused in that some Expy's (even with 4WD) list eSLD on the window sticker and some don't. When one wheel a non-limited-slip-differential vehicle gets on a patch of ice, wouldn't that wheel just spin? And the other wheel on the same axle would receive no power? Then how is it a 4WD vehicle? On my Acura MDX every wheel receives as much power as it needs at any given time. So I just drive normally and if one or more wheels get on a patch of ice, the car stops sending power to the wheels that slip. If I accelerate through a turn, the car sends more power to the outside wheels. Is this what the 4A mode does on the Expy? How can a non-limited slip differential work in 4A?
Sorry about all the questions. It is just all so different from what I am used to. But I love the Expy and can't wait to make the switch.
Soliyou
OK
For a non-limited slip (open diff), yes, one wheel would spin on ice and the other will do nothing. However, the traction control will apply the brakes on the spinning wheel and sends torque to the other to get you out.
The 4A refers to the transfer case that can modulate the power between front and rear axle via a wet clutch pack. This prevents binding on paved surfaces.
This system cannot overdrive a single wheel like the Acura’s
But with eLSD and clutched transfer case, the expy is phenomenal on snow. I only wish they have a locker on the front diff.
Calidad
California
ESLD vs just basic 4H is just more complex technology in the axle. Your Honda is a clutch / friction driven system paired with the ABS the simplest way to think of it is the car uses the brakes at each wheel to prevent excessive wheel spin. That spinning wheel gets braked and when that occurs the power gets pushed across the drive system to the opposite wheel.
The more complex the system is at not just limiting wheel spin and shifting power through the drive system the more complex the traction logic can be. The higher the trim package the more technology you typically can get.
For example the XLT with no trailering package simply has 2wd and 4wd and basic modes Snow -dirt etc. In this configuration it doesn’t have the costly clutch system and the modes primarily just alter throttle sensitivity, power reduction due to wheel spin sensitivity and likely some steering rack sensitivity.
The higher trim models get the more expensive clutch based system which gives more control to the modes and 4wd settings in how much power goes where when etc. Like your Acura but with far more logic in the various modes.
Yes the Expeditions use braking force to limit spin or push power across open diff to opposing wheels. The braking system is the most basic and rudimentary aspect of these systems. But with esld technology it can be paired up with pretty impressive logic to work in conjunction with the power system and be quiet good at finding traction when little traction is to be found.
Gumby
Beaumont, Alberta
My platinum has 4A only. That combined with the various drive modes works perfectly. In the snow, in 4A with SNOW mode is fantastic....and we get lots of snow (deep) and ice along with -40C temps. When paired with dedicated winter tires, you are good to go.
Expedition Dave
A Tiny Little Dot in Florida
2wd is standard and AWD (often called "4wd") an option.
To get proper 2WD, 4hi, 4low and terrain management (and maybe the e-Locker) I believe you have to go with either the FX4 package and/or the Heavy Duty towing.
I have both, so have all.
Like the Chevy, if you want 4 low it needs to be part of the option box check as it is not standard with "4wd" (AWD) any more.
E
ExpyG
Boston
Thank you all so much! If I am not planning on any towing, but only concerned with ice/snow and handling, should look for a vehicle with eLSD or is the XLT 4x4 enough?
Calidad
California
4x4 or 4A is plenty it’s basically the sane as your Acura though I do believe Ford has given it far more logic than the hands off basic FWD biased Acura system. If anything you’ll likely find it better than the Acura.
Soliyou
OK
The Acura system is actually a very advanced system since it is capable of sending more power to the rear axle and put all the power only on one wheel! You really get some rear wheel drive dynamic with this system. In sticky off-road situations, you just maintain steady gas pedal pressure and it will figure it out for you.
I would vote for eLSD if within your price range.
grumpyoleman
flyover country
I have had my XLT with 4A only for two Dakota winters now and no regrets. I don't do any off roading (nothing serious anyway) but it gets me to work without any serious drama no matter how much white stuff is being blown around...
Calidad
California
You do realize this is industry standard with all modern platforms right? Well except for Toyota they are still lagging.
Brake vectoring technology is very simple and cheap to have on all modern ABS vehicles. The Acura is not special today its simply just average
