CRANK, NO START.....2004 - 4.6 - XLS - 19.7K MILES - BOUGHT NEW
Don Hall
SANTA CRUZ, CA
CRANK, NO START. HAS HAPPENED 3-5 TIMES OVER 3 TEARS. PRESSED FUEL RESET SWITCH, NOW RUNS WELL.
DO NOT HEAR A DISCERNABLE "CLICK" WHEN DEPRESSING SWITCH.....
SHOULD THERE BE A 'CLICK' WHEN PRESSING SWITCH?
SYMPTOMS: DO NOT HEAR FUEL PUMP RUN PRIOR TO START. IS THAT A PROBLEM?
WHAT MAY HAVE CAUSED SWITCH TO TURN OFF..... NO COLLISION, NO ROAD BUMPS, ETC. ?
TRUCK USED SPARINGLY, MAY GO A MONTH OR TWO WITHOUT OPERATION....PROBLEM?
REPLACE RELAY?, BY-PASS SWITCH? LEAVE SWITCH AND RELAY ALONE?
HAVE NOT TESTED FUEL PRESSURE YET. IF TRUCK RUNS AFTER FUEL RE-SET SWITCH ACTIVATION, DOES THAT PRECLUE A FAULTY FUEL PUMP?
Hamfisted
Ft Lauderdale
Could just be a weak switch. Vehicles that are rarely driven develop weird issues. The switches are cheap if you just want to replace it to eliminate it as a culprit. Other than that you'd have to do a fuel rail pressure test when your No Start problem is happening and start chasing other things. But since you've narrowed it down in the past to the fuel inertia safety switch I'd start there.
Ford Expedition Fuel Pump Inertia Safety Switch
Don Hall
Don Hall
SANTA CRUZ, CA
Hamfisted, thank you for your informative reply.
Re the switch: does a properly working switch click when activated? My switch is just soft to the touch, no click. While my son turned the start key, I kept pushing the switch,
and the truck started and ran. Do I by-pass the switch, or replace with new?
