dirty motor sparkplug change
Rockunlimited2
Omaha
So I just pulled a P0308, put a new COP, and plug, the plug looked like crap, so I am going to chnage them all. But this is my first time, I have worked on a lot of motors, but the 5.4 is the stupidest design I have ever seen. How the hell am I suposed to clean the spark plug holes out before I remove the plugs when they are just full of crap? I have never seen vertical holes for plugs. For the 8th cylinder, I used some surgical tubing taped on the end of a shop vac. It worked but I know it did not get as clean as it should. If I am repalcing the plugs anyway, should I just fill the holes with soapy water while the plug is still in and they shop-vac out the water/dirt before pullijng the plug? I do not like the idea of grit getting in the cylindrs and also do not want the moisture to get in either. I dont think compressed air will do enough.
gearjammer
Milwaukee, Wi
gearjammer
Get yourself a portable air compressor & a blow nozzle & turn up pressure all the way & blow the crap & grime out of it. With enough air pressure it should clean everything out of the way. No need for shop vac or soapy water
CortezXP
Queen Creek, ARIZONA
let us know how it goes with spark plug change. i have a 2005 expi w/ 89,000 mi on it and im afraid to change em cause i've heard horror stories about it.
