Have you followed the de-initialize instructions immediately followed by the re-initialize procedure, to the letter ?
And just so I am clear, when you press and hold the switch either up or down, the window works 100%. I wouldn't replace the motor based on that, LOL.
The only issue here is express mode requires 8-10 taps.
Out of curiosity, does the obstacle detection work? Lower the window, hold the switch to raise and when its coming up hit the top edge of the glass with your other hand. The window should immediately stop.
When holding the button down, or just hitting it quickly, it stops, on it's own, it takes being tapped or held down, for it to go any further. It seems where it stops is the same each time. But yeah, it takes hitting it a total of 8-10 times to get it all the way closed or open. It is rather commanding in it's speed though. especially after lubing- maybe even faster than the other windows, it just stops on it's own after and inch or two.
I haven't tried obstacle detection yet...
I guess no matter what it does "work" I just want it to be back to normal.
I'll try the obstacle detection and re-and de-initialization procedures again tomorrow, and report back with what I find.
Thanks to all.
