jeff kushner
Since I "do math" for a living (Mr Manziello would have been proud), I love these discussions.
If the debate is "which engine costs more/less" then don't forget to add in development/engineering cost and extrapolate across the number of engines produced to date. This tends to typically run at a higher % of an engines cost over the first 3 yrs of production, makes sense, right? How long has the 5.4 been around vs the 3.5? This can also skew your results if you are solely looking for dead costs of manufacturing.
My guess is that JE is correct, the material costs(pistons, rods block material,cams, etc) & their associated labor probably outweigh the 3rd party vendor deal for a half million turbochargers at a huge discount added to their other assoc. costs like the wastegates, valves and tubing.
The more modern computer control sys is installed on all vehicles with varying degrees of utilization by model/trim, so that's a tricky one to quantify because the base software allows for boosted or N/A operations on the same platform.
The thing is, don't we really need to know the number of steps in the production line, number of operations to quantify the labor for each? I'm not sure.....
I remember my fiance in the 70's had a '75 Bonneville....last of the Big Boats. I forget the engine size but it was a big v8, maybe a 390 or 402?.....but when I pulled the heads to replace the hyd lifters, I found it had teeny tiny valves....no wonder it barely had 200HP!! That was the 1st step taken to reduce emissions....reducing valve size it was reasoned, would work because a car can't burn what it's not able to breath.
jeff
jeff
