Good way to look at it.I was there when they ran all the computer test, compression test and oil pressure test, and they decided to remove the rocker cover. Had Broken rocker, damaged the cam, also removed the pan, turns out pieces of the cam tensioner plastic was also in the pan along with lots of metal shavings. So apparently had other things going on.
I always run synthetic oil. Inside the engine looked like new.
As mentioned above.........Forced engine purchases turn out to be blessings in disguise.
No other problems with anything else on the truck. Cheaper to spend $7K than $70K on a new expedition, and I keep my V8 !! It's paid for !! and with a new engine...
Stuff happens, so I move on.
My next comments about a miss was going to be rocker arms or valve train components but that simply would not be when it's cold only. You would always have a dead cylinder miss when it was running even after it warmed up. It might be less noticeable but in Drive and even under light load you would certainly feel that cylinder missing and should also have a check engine code light pop on because the computer would know that cylinder is missing.I was there when they ran all the computer test, compression test and oil pressure test, and they decided to remove the rocker cover. Had Broken rocker, damaged the cam, also removed the pan, turns out pieces of the cam tensioner plastic was also in the pan along with lots of metal shavings. So apparently had other things going on.
Weird how you can see the owl's diagonally moving second eyelid.The trucks inner owl doesn’t buy it:
Dealer found the problem. Looks like I waited too long to address the engine miss and the ticking on start up. Apparently there was a TSB several years ago on this issue. Number 8 rocker broke damaged the cam, small metal parts all throughout the engine, pan had lots of metal. Apparently a piece the plastic cam timing slack adjuster broke off and plugged a couple of oil passages.................need I say more. New re-manufacturered Ford engine ordered. Supposed to have several of the problem issues resolved on the new engine. Wont be trading for awhile.
Thanks for everyone's time and suggestions !!
Steve
I don’t think a stored low pressure warning has to do with a P0308 misfire code, you’d have timing related codes and noises one would think. They cannot check oil pressure on this engine via computer it has to be done with a manual gauge put on with an adapter so that diagnosis is fishy. Dash gauge just goes to middle at 8 psi and doesn’t show actual pressure.
Sometimes it’s tough to get a good diagnosis. When mine was misfiring and noisy the mechanic said I needed a new engine. I had to figure it out myself and found 4 loose spark plugs. Replaced those and noises and misfires were gone.
I understand it's a nice feeling when it's all done I just don't see why more people don't go buy a good used engine and install.I had this exact same thing happen to my 11 last summer. Spent about 6k installed on the "new" re-man with an upgraded oil pump and a 3 year unlimited mileage warranty. It hurt the wallet but way cheaper than a new rig and I see a noticeable increase in performance. Also, spent another 1K on a few minor upgrades and replacements while they had the front end opened up such as the water pump/belt/hoses. It's basically all new in there.
Well, LKQ is what I call a junkyard anyways so I wouldn't recommend against junk yards in general. I would definitely want to know the mileage on the engine or even hear it run. My LKQ gets tons of running vehicles in there all the time.Depends what your time is worth. If you make a lot of money you are losing money doing an engine swap yourself, just pay someone to do it. I’m in college full time and work part time, for me the only option would be to order the reman and install myself. Only valid reason for the earlier would be to do it for enjoyment. I advise to not buy junkyard engines there is no rules or body for verifying mileage. If you must buy a used engine get it from Copart or LKQ (insurance total losses) because they indicate actual mileage and have return policies should you get a dud.
All very probable. You can even have a bad spark plug that leaks around the insulator or misfires until it gets warm and things start expanding.Bad injector at #8.
PCM will run injector duration open longer when engine is cold (Rich).
Carbon fluff on plug indicates rich mixture and fouling
Fouling and wet plug creates misfire condition on #8 cylinder
Engine at full operating temperature will result in PCM reducing injector opening duration (Lean)
Leaner conditions in #8 cylinder plus full operating temperature will dry fuel saturated plug and misfire condition will be gone.
You didn’t mention which cylinders you changed coils on.. best to replace all of them at once.
Don’t use Accel coils
Find another dealership for servicing your vehicle.
Well I guess we wait, could always be a follower or valve spring problem under there. Could also be computer related. But them replacing the timing set and cams or a new engine isn’t going to fix a cold misfire that disappears when warm on your current engine lol....I’m not convinced they are in the right track but maybe they are who knows
Jeff presented a great point about the vac line as well below \/
You really shouldn't be getting any misfires. I don't consider an 05 old at all. I have a daily driver 98 and a pickup truck that's a 93 that sits for months at a time. They both start up and run perfect with no misfires or issues whatsoever and neither one has had many parts replaced or been religiously maintain. They've been quite neglected.Hey all, This is my first post so here's my two cents worth. Bought '05 a couple of years ago and although it was generally healthy it had the same type of issues that you are having. Weak power and miss fires running up and down the banks. Plugs and coils replaced with some improvement. Given the age of the vehicle and considering the maintenance wasn't great I started changing out the basics. My greatest response came from of all things the replacement of the fuel filter. It really helped out on just about everything. Of course several months later the fuel pump gave out too. However changing that out didn't make any performance changes that I could tell. The last item that took care of rough idle and low power was the MAS. That seemed to be stuck at some restricted signal output that caused the computer to limit its schedules regardless of engine temp or RPM. My engine now has so few bits of rough idle and misses that it's the exception rather than the norm. The power is back throughout the RPM and peddle range and fuel milage went from 12.5 to 15.1. I think I may replace the oxygen sensor next to see if that finishes it off. Remember that it may not be the plug, coil, or engine mechanicals but the computer responding to garbage in, garbage out. The electronics feeding the computer may not have failed outright but are diminished in their operational capability. At the beginning I did have a shop look at it with their analyzer and it came back with non conclusive results and mechanic recommendations to do all sorts of expensive stuff. The fuel filter and MAS are inexpensive by comparison even if they don't totally fix you problems you can at least eliminate that from you list of possible culprits.
What area are you in where engines are so scarce?Well, when I had a shop do mine it was because I couldn't find an engine with under 150,000 miles on it, and they were all around $2200. Yes, I paid about twice that plus labor, but it was done in a week and came with a warranty. I use my truck for search and rescue, I've done a ton of custom work to it myself, but for the engine? I need it to run, and I need it now. The extra $3,000 I paid was worth it to me.
