This is for the right side Make a copy, take it to the dealer and ask them why they want to pull the engine?
Then give them a copy and tell them where to stick it and find another service shop.
this procedure was copied from
SECTION 303-01: Engine 2007 Expedition/Navigator Workshop Manual
IN-VEHICLE REPAIR Procedure revision date: 08/10/2006
Removal
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
Remove the RH inner fenderwell. For additional information, refer to Section 501-02 .
Remove the RH engine support insulator. For additional information, refer to Engine Support Insulators .
Remove the 2 bolts and the exhaust manifold heat shield.
Remove the 8 exhaust manifold nuts, studs and the exhaust manifold.
Discard the exhaust manifold nuts and studs.
CAUTION: Do not use metal scrapers, wire brushes, power abrasive discs or other abrasive means to clean the sealing surfaces. These may cause scratches and gouges resulting in leak paths. Use a plastic scraper to clean the sealing surfaces.
NOTE: Clean the sealing surfaces with metal surface prep. Follow the directions on the packaging.
Remove and discard the exhaust manifold gaskets. Clean the sealing surfaces with metal surface prep.
Inspect the exhaust manifold. For additional information, refer to Section 303-00 .
Installation
Using new exhaust manifold gaskets and studs, position the 2 gaskets and exhaust manifold and install the 8 studs.
Tighten to 12 Nm (9 lb-ft).
Using new exhaust manifold nuts, install the 8 nuts.
Tighten to 25 Nm (18 lb-ft) in the sequence shown.
Position the exhaust manifold heat shield and install the 2 bolts.
Tighten to 10 Nm (89 lb-in).
Install the RH engine support insulator. For additional information, refer to Engine Support Insulators .
Install the RH inner fenderwell. For additional information, refer to Section 501-02 .
