Wayne Decker
Use a weight distributing hitch.So I’m about to pick up a trailer... should I just buy these now or wait and see how the rear does? 400lb tongue 5000lb trailer.
I get rear suspension sag like you do. Really wish the Expy had rear load leveling suspension. But I am happy with the engine and it's towing capabilities.
I can’t, it’s a overland trailer with a articulating mount instead of a ball.Use a weight distributing hitch.
THX!Nice boat. Is your trailer adjustable? I've adjusted several boat trailers. The axles can be moved forward or moved back to put more or less weight on the tongue. If its adjustable, there should be bolts on the frame. There would be predrilled holes in front of them maybe about 6 inches apart. If you decide to move it, buy all new bolts. Launch the boat. Keep trailer hooked up to truck. Remove bolts with a breaker bar. Some may break if too rusted. Then slide axle forward to the hole and put the new bolts on.
I have not heard of them... I'll look at adjusting the trailer first come spring and then if that doesn't work, then I'll look into Sumo Springs. Thank you.Have you looked at Sumo Springs? Only thing out (that I can find) that may work for the 18+ Expy.
THX!
I'll have to look to see if the trailer is adjustable. Thanks for the heads up on adjusting it.
I’ll never tow just this trailer, I’ll have gear in the back of the vehicle as well. I’ll wait and see how bad it is before making a decision.@Artie
No way... you will sag like it do. I would like to tell you different. I believe my setup in right around or under 400 lbs T Weight.
