Expy Crash Test Question
HarryBo
Canada
New tests show Expy doing very poorly on marginal offset front collision tests. Definitely need wheel well frame extensions like in F150s.
Anyone find solution? Thinking of buying F150 extensions and welding onto frame if can work.
HILLY
Greenville, SC
Right or wrong, I'm seriously considering the Ironman full steel bumper for the F-150 that Lumberjack and another member have put on their trucks. The beam behind the Expy bumper cover does not extend much past the frame rails. The F-150 has bumper "horns" that are fitted behind the steel bumper that definitely helps deflect energy in the offset crash.
aksarben
Rockies
Wow - not cool. You would think a big vehicle like this would offer better driver protection. Kinda sickening actually. So, if I see someone drifting over I should steer into them to keep the impact more "head on"? That's bad....
bb37
Member Relations Specialist
Indiana
Look more closely. All those test results are for 2023 or 2024 models. I don't see any tests for 2025 models.
DieselMonk
Atlantic Canada
You got to use this crash test data a little bit like a grain of salt. First they are always changing the way to test things and add that to the list. Specifically the overlap test. I never would drive little small cars. Maybe in the city only but other than that, nope. Plus you always got the option to install a heavy duty push bar on front on the Expy.
rd618
new york
Yes. Applicable for everyone posting in the Gen 4 side, post 2022 refresh.
rd618
new york
The part almost everyone forgets is physics. Bigger vehicles have more mass. More mass at the same speed has more force. The force has to still be absorbed in a small space and time.
you can mitigate this with more robust cages but that adds weight, which reduces fuel efficiency, which consumers shop around for.
Smaller vehicles have more flexibility in cage construction and they “bounce” more in these tests.
DieselMonk
Atlantic Canada
Just happens to be that the 4th gen Expy limited is one of the lightest full size SUV compared to the other brands.
