Yes, it displays something similar. Can’t remember which are there and aren’t. Haven’t been in that area in a while. Been tweaking Sync 3 v3.4 lately.
None of those will get you the display on the Left MFD, because the BCM does not control that in most vehicles.
I have said this SO MANY times in so many threads on here, I feel like I need to save it to post it.
The BCM has the Data, but in all other Fords of this gen that I know of the DDM controls the left MFD, and the PDM controls the Right MFD. The 15-17 Expy has neither module. The ability to display might be there, but there is no reference to know the coding. The way these changes are typically discovered is using code from a vehicle that has the feature to give it to a vehicle that doesn’t. No reference vehicle in our case. Other than literally changing random bits, It is tough to know what needs to be changed. I have tried coding from MANY other Fords of similar years.
I moved on.
I use a Kiwi 3, and mobile FORSCAN or OBDLink to display pressures and other things, like IAT1 and IAT2. It works really well. I leave it attached all the time, and connect when I want to see info.
Again, the BCM has the Tire Data and way more, and the adapter and program allow you to access it.
