I have had a clunking sound from front end for a while. Changed upper and lower control arms, outer tie rods, stabilizer bar bushings, stabilizer links, hubs and alignment two times. Inner tie rods are fine.
Last inspection said I have play in steering rack, and for sure there is where the sound is coming from.
I removed steering shaft, cleaned and lubricated it, and when I wiggle the shaft while disconnected at top, I can hear the sound.
Rack and pinion can be adjusted, but space is tight. i will try to tighten it one day, to get rid of play and sound.
Might be the same problem you have.
