Thanks everyone for the info. The fuel inertia in the back seems to be a reset only button with nothing to turn it off or at least I can't find it. Pressing down does nothing. Anyhow, unplugging the cam sensor worked.....it was all for not because I couldn't get the compression tester to thread in the plug hole. My guess is you need a longer thread attachment..... I've spent $500 bucks for a dealer and other centre to do electronic analysis and all I know is I have a missfire and bad relative compression on the one cylinder (which in all honesty I don't understand accuracy of relative compression or if something like a bad COP or PCM would trigger false results). I'm about to give up on this expy and send it to the auction.
There is no oil burning or coolant loss, engine sounds smooth but shakes a little at idle. The shake increases underload and will set a P0 175 (Rich on Bank 2 - same side as Miss Cylinder). Changed plug, tried now COP changed injector). The plug was a little wet with gas when I pulled it again. The question is now should I spend another 120 bucks to do a leak down test only to potentially learn the engine is toast.
I have never had an electronic relative compression test performed but my best guess is it determines how much each cylinder contributes to the power output. If this is the case then a misfiring spark plug, faulty injector, etc... could effect it. For instance if one injector does not spray a fine 30 deg conical mist but sprays a stream of fuel.... that cylinder may not contribute to the power output as well as the others as the fuel atomization is not as good.
Again I do not know the specifics of the relative compression test so just speculating.
I have done compression and leakdown test before. Leakdown test is best to identify where the problem lies if indeed there is a mechanical issue but requires use of an air compressor. It will tell you nothing as far as fuel and ignition.
You are correct about the inertia switch. It only "trips" when you are in an accident or it senses high g force. Resetting it does nothing unless it has tripped.
