gas tank vapor valve cracked
vandep32
hawaii
I have a 04 expedition, 4.6L. I noticed a leak from the front of my gas tank after I fill up. I decided to drop the tank and take a look. Turns out the front vapor valve is cracked and leaking gas when i have it filled up. I can't seem to get the valve off the tank. Is this thing permanently attached? What is the easiest way to fix this?
Herb
Orlando Florida
Any luck?
I just noticed a leak in the same area after a fill up but only when parked facing downhill, no time to investigate, going on a 1400 mile trip....wish me luck
whitelightning99
Pa
not sure if it could be epoxy or not but might give that a thought, iv used gas tank repair it's almost like jb weld with decent results if you prep the area good enough just an idea sure someones goona hate on this idea though oh well
