Groaning noise coming from the front
Robert Smith
Reno, NV
Happy New Year everyone.
I was greeted on my New Year with a groaning sound coming from the front on my Expy. Driver side, I think although it’s hard to tell. It seems to occur during a slow speed deceleration, like coasting to a stop but not yet applying the brakes. However I think it occurs after I have already applied the brakes and let off pressure. Like slowing to a yield then turning without stopping. Then slowing again. I just had my brakes inspected by my normal mechanic but I also realize something could have happened.
Any ideas??
Dakota4ce
South Dakota
You’re losing a hub bearing most likely. Same exact thing my 16 did.
Well maybe “most likely” is a bit strong, but this sounds familiar.
Calidad
California
Could be anything unless you can trigger it or alter its groan effect with brake pressure which case even a rock caught in a brake shield could be the cause. As mentioned wheel bearings will give a groaning effect but usually people notice loud tire noise at speed first then discover its not a tire but a bearing failing.
could one of the sound carpets in the wheel well be loose and catching or dragging on something?
F150 Pat
Geneva, Illinois
I also have a very light groaning noise coming from my left front. Sure its just coincidence its the same side but something is going on up there. Braking has no effect. Very subtle. Jacked the wheel up. Spins perfect. Nothing rubbing nothing loose. Going to have to wait until it gets more noticeable before I take it in.
Robert Smith
Robert Smith
Reno, NV
Fishrising - no. Not yet.
Sorry about posting my first question in the wrong section. This is the only forum I use and still learning.
Dakota4ce. I thought that as well. My mechanic recently told me it was the front differential
rlgosnell
Quincy, IL
Any ideas??
Did you ever diagnose your issue? I'm having the same problem. Thanks!
PalosX
