5280tunage
Exactly, the systems are in place to make it much safer and better, it's simple code.
Just give it time. You'll eventually have it close on you while unloading groceries, while your kids sit on the bumper, or maybe it will open when you walk by the car while it's in your garage with the garage door closed. Too many issues, I disabled mine.
It's one of the dumbest systems on the car. For one, it will open even if the lift glass is open. Second, I don't see why the stupid system doesn't use the parking sensors to also determine if there's a stationary object behind the car, and prevent it from opening. I also don't think it should close via handsfree if it wasn't opened that way to begin with.
You can disable the power liftgate through settings, but that completely disables the power, so you have to pull it open and push it closed.Can anyone please walk me through step by step to disable the tailgate in settings? I can’t find it.
I'm looking to disable the hands free tailgate function on my 2020 Expedition Platinum in Forscan. I've searched this Forum and Forscan Forum and you are the only one I've found to do this in Forscan. I have been hit by the gate numerous times by simply walking by the rear of the vehicle. I know this is an old post but do you have a spreadsheet or can you please tell me the correct address and changes you made in Forscan to accomplish this? I believe it is in Module 775 which only contains 5 addresses according to my As-Builts.I actually did it last night, with the current version of Forscan, you can disable the handsfree liftgate via the configuration wizards. So glad I did that. Went ahead and changed the APIM splash screen while I was in there. Disabling the liftgate via Forscan feels so much better to me then having disconnected wires hanging out in the bumper.
I didn't want to lose the power liftgate feature, but was tired of it closing on me and opening when I didn't want it to. So, I used Forscan to disable it.I'm looking to disable the hands free tailgate function on my 2020 Expedition Platinum in Forscan. I've searched this Forum and Forscan Forum and you are the only one I've found to do this in Forscan. I have been hit by the gate numerous times by simply walking by the rear of the vehicle. I know this is an old post but do you have a spreadsheet or can you please tell me the correct address and changes you made in Forscan to accomplish this? I believe it is in Module 775 which only contains 5 addresses according to my As-Builts.
What he said!I didn't want to lose the power liftgate feature, but was tired of it closing on me and opening when I didn't want it to. So, I used Forscan to disable it.
Start FORScan go to bdyCM Module Configuration (not AsBuilt), look for "Hands Free Liftgate", double click on it and select Disable and save it.
Then try opening it hands free. If your mod was successful, it is disabled and won't open, unless you revert back to the factory setting. Your open and close liftgate buttons still work as expected.
