Headlight and grill removal
Pedition2000
North Carolina
Loiked through the forum and couldnt find what im looking for. How is the grill and headlights removed? Also, any recommendation for clearing the haze or is getting new ones the better route? Im hoping removing fogs is an easy process, but havent looked yet.
Thanks.
Sent from my SM-G935V using Tapatalk
74c5
Salt Lake City area, near the mine
Headlamps come out to the front after lifting the two black clips in the back. Look at the back of the lamps for two black angled stubs made of flat metal. That's them. Pull them up to release the lamps. You might need and extra bit of emphasis to get final release.
1955moose
The haze on the headlamp housings can be buffed out some what, you'll need to buy one of the headlight restoring kits, use a drill, and go at it. Problem is even if you improve them, doesn't last. You'll need to redo every 2 months or so. You can spring for a new set of clear coated ones, but buy the better ones, cheap ones lose their clear coat way too soon.
