Help smoke on start up
Brusky
Florida
Recently I have noticed this smoke only on start up for about 5 seconds then doesn't do it again until it has been setting for at least an hour or so then same thing. ?
B
Brusky
Florida
Another pic. Sorry my phone won't allow me to post more than one at a time
Temple, Georgia
Valve seals/guides are worn letting oil into the cylinder once the engine is stopped. Also is happening when running but not as noticeable. You should also see the oil level dropping over time if it is really bad.
B
Brusky
Florida
Why would it all of a sudden be this noticeable. Literally just within the last few weeks?
B
Brusky
Florida
5w20 126,000 on. The clock.
Bought it with 80,000 and have run whatever full synthetic is on sale the week I change my oil. Change it pretty much every 5000 miles. And never had a problem until now.
Since my first post I just changed my oil about 30 min ago bc this problem really worrying me and was extremely surprised to find only about 3 quarts drain out.
So I changed it as normal but added some Lucas stabilizer with it. I'm not normally a fan of additives but my cousin swears by it so I thought mabe it would help with preventing any farther wear.
Temple, Georgia
You may consider changing to a slightly heavier oil, I'm running 10w30 in mine with 211+ on the clock.
All that has to happen is one seal lets go and you start the morning smoke. If you don't have emission testing I wouldn't worry too much about it unless the oil consumption is high and/or the plugs start fouling.
Lightnig
Behind you
I am with stamp on this one
That is the dictionary description of the classic leaking valve seal issue...
98EXPY 5-0
PA
Stop the presses. I had the same problem and when I searched, leaking valve seals was the number one "answer". However, the number two answer cost me $5 and worked. I replaced the PCV valve on the passenger side valve cover. It fixed my issue.
The concept being that as the motor cools, the PCV valve should let the crack case vent but instead, the drop in temp creates a suction that pulls the oil past the seals. I'm not saying that your valves aren't bad, but mine hasn't smoked since and I believe in trying the $5 fixes before the valve job.
