Update
Look at the prints I posted Then use your volt meter and put one lead on ground and the other lead onto fuse 21 in the CJB then turn the key on you should have 12 volts then check the other side of the fuse doing the same as above
So I haven't had no time once again to mess with the expo and the starting problem. I moved to another state, so working and trying to move is easy.
Butttt... shes been so weird. For a whole day it started with me turning the key, no problem. The next day, it doesn't start. Same symptoms.
Today I switched the key to ignition and nothing, I slam the key hard all the way back (to the point where the car isn't running, but the radio plays for a little until you open your door) and then turn it all the way to ignition and bam. It started.
By the way, the ignition switch, starter relay(on firewall), and the starter itself is brand new. I did have time to spend money tho. I know it's not the right way of doing things but I had to try and fix this before moving. Now I have time and a new dmm.
I checked fuse 21 and get 12vs when I turn the ignition switch.
Now what should I check?
