HID headlight upgrade
jeff kushner
North of Annapolis
One of the 1st things I did when I bought my '17 last November was to switch the headlight lowbeams to LED so the headlights and fog lights would match. I did a write-up somewhere....cost less than 50 bucks total as I remember!
Careful though, the manual was WRONG! Said I needed H11's and they weren't! They had actually installed HB-3's!!
jeff
Bigbadbull
Hoover Al
jeff
Yep I ordered the 9005's which I think are also known as HB-3's
The H-11's are what I have in my 2011 F-150 ( year before the HIDS came out for them ) and are hi/low single bulbe or is that the h-13?... cant remember at this point.
Bigbadbull
Hoover Al
So I got the Morimoto LEDs in last night..
Brighter yes
Color temp is much better at 5500k , I find it easier to see at night and matches the fogs
Not sure if the Light throw is farther than the halogens.
Ill see if I can get some picts. I had to seriously modify some throwaway rubber housing caps as the radiator and cooling fans on each LED were HUGE and stuck out of the housings a good 1.5-2". Install was not too bad, other than the end caps. They were a very tight fit in to the housings though. Wife seemed happy with them this morning on the way in to work.
The beam pattern is different than the Halagens when I tried to adjust them. The projectors with halogens were more like -0-0- vs the LEDs were =/=/= the hot spots were more uniform than a big circle with some side light.
Im still out on the fence over if its an improvement distance wise. I guess I will find out this weekend as we have a long 12 hour road trip for vacation.
Adieu
SoCal
Brighter yes
That's messed up
You're not supposed to be getting any noticeable hotspots from this stuff
gixer2000
Retrofit or Bust
Massachusetts
Can you get some pictures 25' away from a light colored wall/fence/house or whatever work. Its gives a much better idea of the beam pattern and hot spot alignment. Something similar to this picture
Bigbadbull
Hoover Al
After driving 1200 miles back and forth and about to Fla.. I can say I am happy with the LED's
Held up to tropical storm levels of rain and wind.
Light color Im happy with. Could it be a longer throw , Im sure it could be with HID's, but Im fairly pleased.
I did not get flashed with on coming brights either for being to bright or miss aimed.
davidowl12
new mexico
Hey quick question, I’m looking into buying morimoto 2stroke LED bulbs but wanted to know what size housing caps did you end up purchasing ? I have a 2016 with just standard reflectors and can’t find anything on if I need a housing cap or not. Figured you may have an answer.
