Horn problem.
Erich Zeppelin
Destruction Bay, Yukon Territory
My horn sounded like something on a little import so I checked it out. One of the two horns failed so I bought a new one, hooked her up and now she's nice and loud. The problem is that I have to press all over the steering wheel to find just the right spot to set the horns off. Really don't want to mess around with that airbag, how can I fix this?
tonydiv
technical advisor
Middle River, MD
There's no way to get to that horn 'switch' without pulling the airbag off.
You could always install a remote switch for the horn. Not an elegant answer to the problem though.
B
bedrck46
to remove air bag
The following was copied from the 99 ford service manual
WARNING: Always wear safety glasses when repairing an air bag supplemental restraint system (SRS) vehicle and when handling an air bag module. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: Carry a live air bag module with the air bag and trim cover pointed away from your body. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: Do not set a live air bag module down with the trim cover face down. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: After deployment, the air bag surface can contain deposits of sodium hydroxide, a product of the gas generant combustion that is irritating to the skin. Wash your hands with soap and water afterwards.
WARNING: Never probe the connectors on the air bag module. Doing so can result in air bag deployment, which can result in personal injury.
WARNING: Air bag modules with discolored or damaged trim covers must be installed new, not repainted.
WARNING: Vehicle sensor orientation is critical for proper system operation. If a vehicle equipped with an air bag supplemental restraint system (SRS) is involved in a collision, inspect the sensor mounting bracket and wiring pigtail for deformation. Replace and properly position the sensor or any other damaged supplemental restraint system (SRS) components whether or not the air bag is deployed.
WARNING: To avoid accidental, deployment and possible personal injury, the backup power supply must be depleted before repairing or replacing any front or side air bag supplemental restraint system (SRS) components and before servicing, replacing, adjusting or striking components near the front or side air bag sensors, such as doors, instrument panel, console, door latches, strikers, seats and hood latches.
Please refer to the appropriate vehicle shop manual to determine location of the front air bag sensors.
The side air bag sensors are located at or near the base of the B-pillar.
To deplete the backup power supply energy, disconnect the battery ground cable and wait at least one minute. Be sure to disconnect auxiliary batteries and power supplies (if equipped).
Disconnect the battery ground cable (14301) and wait at least one minute. For additional information, refer to Section 414-01 .
Remove the two back cover plugs from the steering wheel.
Remove the two driver air bag module retaining bolts.
Remove the driver air bag module.
Disconnect the driver air bag module electrical connector.
Disconnect the horn switch electrical connector.
Installation
NOTE: Repair is made by installing a new part only. If the new part does not correct the condition, install the original part and perform the diagnostic procedure again.
NOTE: Make sure to tighten the retaining bolts to specification.
To install, reverse the removal procedure.
WARNING: The restraint system diagnostic tool is for restraint system service only. Remove from vehicle prior to road use. Failure to remove could result in injury and possible violation of vehicle safety standards.
Prove out the air bag system.
Temple, Georgia
In layman terms the airbag is a bomb that explodes in a specific direction. Treat it as such and you will be alright. Watch a few youtube videos on airbag deployments and you'll see what I'm talking about.
If you live on the edge, well maybe not....
IMINYOURCHAIR
Altoona Alabama
just disconnect the battery. wait a couple minutes then remove the two bolts behind two plastic clips. the airbag will have a couple connectors (horn and airbag) it seems scary but when it's not connected it's not as big of a hazard. (although safety should be used)
toms89
technical advisor
MD
LOL... @ safety glasses to protect you in case of air bag deployment.
Somehow I just cannot visualize them being of much help.
