Steve Patterson
I went through a similar analysis and purchased a travel trailer. Below is an overview my experience linking back the "real world" numbers to my spreadsheet numbers....this is my first travel trailer. I have no previous TT experience, but have towed a small utility trailer quite a bit.
The first trip to the CAT Scales with my new loaded trailer and tow vehicle (TV), also loaded, was a surprise....(Loaded, but no water).
After three passes through the scales (Just TV, TV w/ Trailer and WDH disconnected and finally pass three; TV with WDH set up), I found my rear axle was overloaded by about 300 lbs and my front axle was lighter than the TV alone wt by about 150 lbs (not good for steering control).
What was happening (despite my excel spreadsheet numbers), was the down pressure of the tong wt was too much (although in spec at about 930 lbs) and like a see-saw, the back is pushed down and the front push up (lower front axle wt then the TV without trailer). And the WDH was not distributing enough wt to the Front and Travel Tailer Axles (although it was the "1000 lb version")
As a result I did two things: Increased the setting on the WDH (one chain link), and changed the loading in the trailer to reduce the trailer tongue Wt.
I changed the trailer loading while the trailer tongue was on a trailer tung scale (eTrailer, 2000lb max version). I moved two heavy objects from the front compartment to the rear (about a total of 100 lbs moved). I then added about 10 gallons of fresh water for the trip (80 lbs), watching the sale go back up somewhat (about 50% of the water weight would be added to the the tung). I made some other smaller changes, always watching the tung scale. I ended up with about a 820 lbs tung. (Although the CAT scales and my own scale were disagreeing a bit, at least the trailer tung scale was consistent as I re-distrbuted the trailer cargo)
I then took my first trip (1200 miles) and weighed the actual vehicle once again on the CAT scales within the first 30 miles, with a full tank of gas. This time just a quick one pass weigh with WDH hook up, no time to do the three passes as I was on my trip. My axle weights were good and in spec. The TT Tongue wt was about 11% of the trailer.
Although all my weight "numbers" were good and verified, I was very surprised what a white knuckle ride the first two days were. Although no significant wind, about 30 trucks per hr would pass me on the interstate. Not fun.
Some trucks would cause a single sway (never as sway back and forth, so the anti-sway WDH was doing its job), but it was a bit uncountable. Maybe just learning curve towing TT.
After talking to someone end of day 2, on the third and last day, I reduced my speed to 58 MPH as an experiment(from 63-65), and what a difference! Much more comfortable. Wind about 10 MPH.
So although the speed limit was 70, I felt very comfortable at 58 MPH. The lower 58 MPH speed vs 63-63 MPH improved my gas milage from about 8 MPG to about 10 MPG. My trailer is a 25 foot model (29.5 feet long) and a 6000 lb dry wt / 7500 GVWR, and about 6800 as actually towed on my first trip.
Pushing the Expy numbers on a spreadsheet is one thing...but managing the numbers on your actual rig the day you are traveling is another. My set up is "boxed" in with these numbers, and I can't go higher on the Tung Wt percent.
I think the "ideal" maximum TT wt might be about 1000 lbs lighter than my trailer for EXPy. And a few feet shorter. Although I am happy with my choice. I also decided when making the choice to purchase this particular travel trailer, that would go to a 3/4 ton truck if I had to. So far, I am not going to, but that may change as I gain more travel time.
Hope this helps!
A few extra notes on my set up: My tow vehicle tires were pumped to the max (50 psi) tire rating vs the car sticker of 35 psi. Trailer tires to their recommended 65 psi. I also have the shorter (non EX version) Expedition. I do not have the OEM option of air shocks.
Hope this helps!
