broncoremy
info, reset, setup, anti-skid, flasher buttons on the center dash not working.
when you press any of the above buttons on the center console nothing happens.
I unhooked the battery for about 10 minutes to try to reset the system. While the battery was disconnected, I looked for fuses that might have an affect, but looking at fuse 26 and 29 in the passenger kick panel (instrument cluster fuses) showed them to be good. I did not come across others that looked relevant, but there could be others that I missed. Any others that I might check?
I found this issue thread on the instrument cluster that sounds a little similar, but not exactly. My hope is that this is not the cluster.
http://www.expeditionforum.com/f40/information-center-malfunction-20446/
After hooking the battery back up the issue was still there. However, the moment I hooked the battery back in circuit the alarm went off. This has been a recurring issue for me with the alarm going off. Never for my wife, but for me. Maybe we should swap keys and see if the issue follows the key set.
I do not know if the alarm issue might be a part of the cause or a completely different, unrelated issue. This thread details something similar:
http://www.expeditionforum.com/f40/anti-theft-unexpededly-activated-25400/index2.html
Any hints or leads would be appreciated.
