Is that stock or aftermarket? Do i dare use it with engine off, or only idling/driving?
Adieu
SoCal
To my surprise, found an AC socket on my Gator... is this stock or a mod? Do i dare use it with engine off, or only idling/driving?
How much load is OK to use with it?
Thx.
AllBoostNoEco
GA
Based on this, it’s stock.
I’d imagine it can handle the typical amp load of any of the other plugs in the truck, so probably fused at 15.
B-McD
Illinois
Same as in my Expy - I have used it to charge an iPad and my laptop. Have not tried boiling water yet.....
Habbibie
Is it Christmas yet?
Chicago
Its obviously connected to an inverter which needs power feed from the alternator so therefore the engine has to be running yo use it.
ManUpOrShutUp
PA
Stock and it's crap. The metal inside the receptacle gets pushed outwards whenever you plug something in, which results in having to remove the socket and push the tabs back in so they can make contact with whatever you're plugging in. It hasn't broken yet though and I'm cheap, so I'll just keep fixing it. :p
Muddy Bean
It’s limited to something like 120 watts or something. I use it to charge my MAC air. Everything I plug into it falls out while driving. I’d like a better setup. A plug in the front seats would be nice.
Dorzak
California
I have one in my Expedition, and had one in my Jeep Patriot. However in the Patriot you had to be careful because it ran off the battery when key was off and could easily run the battery flat.
AllBoostNoEco
GA
I’m an idiot. I thought you referring to the “DC” socket, not the AC. image.jpg
Cover on mine says 150W. It’s fused higher, but the inverter shuts down if you go above that.
jeff kushner
North of Annapolis
120v 15A = 1800w???? Thats like a friggin tea kettle
Holy shit i can boil water and make cupanoodle in this thing???
NO...you might want to read your manual....chances are, the receptacle will MELT if you attempt to draw 15 amps @ 120v....use your head, you know better! I would expect it to be rated for 3 amps, at most....so, what is the answer guys...who has looked it up?
OK, 1.25 amps...roughly at 120v......because the fuse is 15A SHOULD mean that the fuse is the weak link....but in the auto world, it just isn't done that way!!
jeff
A
Adieu
SoCal
Ahh didn't realize expeditions had em too, my SSV has no console
So 150w eh? Mine's not printed or maybe had a sticker that came off
Which means laptop yay, boiling water nay... gotcha
Does it work with engine off?
ManUpOrShutUp
PA
jeff
I started to read your post, looked over at the avatar, and then ... Yeah I didn't finish reading your post. :)
