Based on this, it’s stock.
I’d imagine it can handle the typical amp load of any of the other plugs in the truck, so probably fused at 15.
120v 15A = 1800w???? Thats like a friggin tea kettle
Holy shit i can boil water and make cupanoodle in this thing???
NO...you might want to read your manual....chances are, the receptacle will MELT if you attempt to draw 15 amps @ 120v....use your head, you know better! I would expect it to be rated for 3 amps, at most....so, what is the answer guys...who has looked it up?
OK, 1.25 amps...roughly at 120v......because the fuse is 15A SHOULD mean that the fuse is the weak link....but in the auto world, it just isn't done that way!!
jeff
