Got a favorite PCV For Dummies source? Maybe I could have tried harder...You guys need to read up on how a PCV system works. Once you do that, you'll understand why it's only pulling from one side.
The only possible problem I see with the cans that don’t separate the oil and the water vapors is that they could freeze overnight when left not drained. My RXP Can just has a ball valve drain on the bottom of the can and doesn’t unscrew apart. I was told by the manufacturer that it has some kind of steel media inside the can. I’m guessing it’s something like steel wool that somehow wicks the oil out of the vapors and let’s the water vapor through to be burned off. I’ve never even seen a hint of water come out of mine yet..... emulsified in the oil or even straight water. Straight unmixed water would be the first to trickle out of the drain when I open it because of it being heavier than oil, but not a drop.No moisture is a good thing right?
