LED bulbs
WarrenK
Oregon
Hi,
For rear turn signal/tail lights I used these and really like them:
https://www.amazon.com/gp/product/B019J59BV0
These are VERY bright for backup lights:
https://www.amazon.com/gp/product/B00K3GBRQ2
For headlights I put these in:
https://www.amazon.com/gp/product/B01JFXUWSC which are pretty good.
I then found these:
https://www.amazon.com/gp/product/B01DYS1GIY are AWESOME!
These EXACTLY match the halogen beam pattern. No adjustment required
and nice even light pattern!
YMMV (and your illumination.)
TTYL
Warren
J Ski
J Ski
3.5plati
VA
Started this morning with the license plate bulbs. Pilot LEDs are what I found. Great fitment, very snug in the housing and definitely have a noticeable difference over OEM as seen here. Now I need to find the correct sized hex head screw driver to remove the tail lightsIMG_3163.JPG
chuck s
Not hex head (AKA Allen), they're Torx. Get one of the multi-tip tools at Home Depot.
The bolts are officially one or the other but both these fit (just now) T15 and T20. I bought a dedicated driver a few years ago but it's buried in my tools somewhere.
-- Chuck
chuck s
Fast Flash can be corrected via Forscan.
Not sure if that will mess with the trailer settings though. I'd not towed my lil' trailer with the '17 and when I hooked up last evening the dash displayed a message that the left trailer turn signal was out. Sure enough it was! It was also rusted into the socket so it took a while to change. I may yet change these to LED.
-- Chuck
J Ski
J Ski
3.5plati
VA
-- Chuck
Sorry but what is Forscan?
J Ski
J Ski
3.5plati
VA
-- Chuck
And is that something that you plug the sensor into obd2 and turn it off and then unplug or do you have to keep the obd2 wifi sensor attached permanently
gixer2000
Retrofit or Bust
Massachusetts
Plugs into the obd2. Read codes, make changes to certain electronics in the pcm,bcm,pats and any other system that's supported. Unplug it when your finished
Adieu
SoCal
Started this morning with the license plate bulbs. Pilot LEDs are what I found. Great fitment, very snug in the housing and definitely have a noticeable difference over OEM as seen here. Now I need to find the correct sized hex head screw driver to remove the tail lightsView attachment 21635
Verrrrry dim vs. Other options
Adieu
SoCal
-- Chuck
Half the stuff in our Fords is assembled with Torx/Stardrive bolts.
Get a good set of Torx or knockoff drivers, preferably impact rated, if you plan to do anything on your car.
Ive used as small as T8 afair and as large as T55 or T60
gnorman
